Introducing the fashionable Acer SA0 series, where the elegantly thin design ensures that the monitor looks great and gives more space to its screen. Thinness is in vogue and at just 6.6mm the SA0 is ultra-fashionable. The stylish base, with its pattern of concentric circles, looks great wherever it’s placed. The content on the screen looks fantastic too - with clearer, sharper images in full high-definition color. IPS technology ensures you can share what’s on your screen with friends and family as colors stay true no matter what angle you’re viewing from. In addition, Acer Vision Care incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
Product Description | Acer SA270 - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class A+ | Energy Consumption per Year | 30 kWh | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) - with stand | 62.1 cm x 21.18 cm x 45.37 cm | Weight | 3.54 kg | Compliant Standards | MPR II |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Flicker-Less technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology, Ultra Thin |
Colour | Black |
Dimensions (WxDxH) | 62.1 cm x 21.18 cm x 45.37 cm - with stand |
Weight | 3.54 kg |
Connectivity | |
Interfaces | HDMI , DVI (HDCP) , VGA |
Mechanical | |
Tilt Angle | -5/+15 |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Power Consumption Operational | 25 Watt |
Power Consumption Sleep | 0.45 Watt |
Power Consumption (Off Mode) | 0.4 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 62.1 cm - depth: 21.18 cm - height: 45.37 cm - weight: 3.54 kg , Without stand - width: 62.1 cm - depth: 3.37 cm - height: 37.17 cm - weight: 3.22 kg |
