Acer T232HLA 23" 1920x1080 5ms VGA DVI HDMI Touchscreen...
Acer T232HLA 23" 1920x1080 5ms VGA DVI HDMI Touchscreen IPS LED Monitor
Key features
  • 23" E-IPS LED display
  • Full HD 1920x1080
  • 10-point touchscreen
  • 100 million: 1 contrast ratio
  • Ergonomic design
  • VGA, DVI, HDMI with HDCP
  • USB 3.0 HUB with power-off charging
Product codes
The innovative 23" touch display is made for users who appreciate state of the art technology and innovative design. Thanks to the edgy design the working angle of the monitor can be adjusted from 5° to 60° to ensure comfort. Areas close to the edges are easy to touch thanks to ZeroFrame design and front glass. In addition to the digital connectivity options you can also connect and power your mobile devices via the USB 3.0 hub. T232HL reproduces consistent and natural colors from all viewing angles, thanks to E-IPS panel technology. Rapid response times ensure the smoothest reproduction of even the fastest videos and a fast, accurate and natural touch experience.
Acer T232HLAbmjjz - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23" - touchscreen
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
USB 3.0 hub
Panel Type
E-IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, MHL
Speakers
Integrated
Display Position Adjustments
Tilt
57.37 cm x 3.8 cm x 42.01 cm
5.16 kg
United Kingdom, Europe, EMEA
Environmental Standards
ENERGY STAR Qualified
MPR II
2 years warranty
Customer reviews
Accessories
Accessories
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer T232HLA 23" 1920x...
