A magnesium-aluminum alloy chassis and aluminum alloy bottom cover make the TravelMate P4 light and strong. The hard drive and RAM are easily accessible, so even office staff can perform upgrades.
Product Description | Acer TravelMate P449-G3-M-57EE - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache | Memory | 8 GB DDR4 (provided memory is soldered) | Storage | 256 GB SSD | Optical Drive | No optical drive | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel UHD Graphics 620 | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell - up to 8 hours | Features | G-sensor | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 34.2 cm x 23.6 cm x 2.19 cm | Weight | 2 kg | Localisation | Region: United Kingdom | Environmental Standards | ENERGY STAR Qualified |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8250U / 1.6 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Max RAM Supported | 12 GB |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD - Samsung |
Display | |
Type | 14" - TN |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare, ComfyView, Mercury free, 180° lay flat, 8 ms response rate |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1280 x 720 |
Camera Features | HDR (High Dynamic Range), 720p HD movie recording, Windows Hello, 88° view |
Sound | Stereo speakers, microphone |
Audio Features | Acer TrueHarmony technology |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19 V |
Connections & Expansion | |
Interfaces | 3 x USB 2.0 , USB 3.0 , USB-C 3.1 Gen 1 , HDMI , VGA , LAN , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Black |
Integrated Options | G-sensor |
Features | Pre-boot Authentication |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI 5.0 |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
