Acer U5320W DLP WXGA 3D 3000 Lumens Projector
£990.55
Delivery:
Product codes
The Acer U5320W is an ultra-short throw projector that can be placed as close as 23cm (9.1-inches) from the projection surface, and the ability to can project up to 100-inch images at a distance of 50cm (19.7-inches), providing greater space flexibility. It also eliminates shadowing and enhances viewing comfort, a significant benefit for classrooms. The U5320W's WXGA resolution and 3,000 lumens brightness creates crystal-clear and vibrant images, while its 2x10W speakers provide powerful sound. When paired with an optional Acer SmartPen II, the U5320W is ideal for classroom settings, allowing on-screen writing from up to a 32-foot distance for up to two users, and working as a remote control to encourage interactive learning.
Product Description Acer U5320W - DLP projector - ultra short-throw - 3D - LAN
Device Type DLP projector - 720p
3D Capable Yes
Built-in Devices Stereo speakers
Microdisplay DarkChip 3
Brightness 3000 ANSI lumens
Contrast Ratio 13000:1 (dynamic)
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Lens Ultra short-throw fixed lens
Bulb type UHP 240 Watt
Bulb life cycle Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input S-Video, composite video, component video (PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
Video Modes 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 299 Watt
Weight 5.5 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer U5320W DLP WXGA 3...
£990.55
