Acer V196LBb 19" 1280x1024 VGA Monitor
£126.09
Delivery:
Key features
  • 19" LED LCD display
  • 1280 x 1024 resolution
  • 100,000,000:1 contrast ratio
  • 5 ms response time
  • VGA, DVI
  • Integrated speakers
  • Adjustable display angle
  • Diagonal Size: 19in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Interfaces: VGA (HD-15)
Product codes
Essential series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Product Description Acer V196L - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19"
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 75 Hz
Brightness 250 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors VGA
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 40.64 cm x 20.7 cm x 40.8 cm
Weight 3.1 kg
Compliant Standards TCO Displays 7.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer V196LBb 19" 1280x...
£126.09
