The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD multimedia and productivity applications. LED monitors also consume less power and last longer than those with CCFL lamps. Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
Product Description | Acer V226HQL bid - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class F | Energy Consumption per Year | 38 kWh | Power Consumption (On mode) | 26 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 50.8 cm x 20.68 cm x 39.05 cm | Weight | 3.66 kg | Environmental Standards | TCO Certified Displays 8 EPEAT Bronze |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | TN |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM) |
Colour | Black |
Dimensions (WxDxH) | 50.8 cm x 20.68 cm x 39.05 cm - with stand |
Weight | 3.66 kg |
Connectivity | |
Interfaces | VGA , DVI , HDMI |
Mechanical | |
Tilt Angle | -5/+25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 1 x VGA cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 19 kWh/1000h |
Power Consumption (Typical) | 16.5 Watt |
Power Consumption Stand by | 0.45 Watt |
Power Consumption (Off Mode) | 0.35 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.8 cm - depth: 20.68 cm - height: 39.05 cm - weight: 3.66 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 3.24 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Bronze |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
