Acer V226WL 22" 1680x1050 5ms DVI LED Monitor
Key features
  • Adaptable
  • Convincing
  • Prepared
  • Green focus
Product codes
Explore the angle that's perfect for you with this Professional Series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Its ergonomic design provides handsome style on your desk - or off: this monitor is wall mountable, giving you clear views with more room. The contrast ratio of the monitor is superior and the response is ultra-quick. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. Moreover, the monitor allows you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA, DVI, HDMI, USB and even DisplayPort connectivity options. Professional Series monitors are mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources. Acer also uses recyclable packaging to further reduce ecological impact.
Product Description Acer V226WLbmd - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Internal
Colour Black
Dimensions (WxDxH) 50.58 cm x 20.7 cm x 41.91 cm
Weight 3.52 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
Compliant Standards TUV GS, ISO 9241-307
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
