Acer’s 24" V247Y monitor is a commercial monitor, designed to meet your day-to-day business needs.
Complete Peace of Mind
All of Acer’s commercial & professional monitors come with Acer’s 3 year commercial warranty, giving you complete peace of mind that the V247Y will be reliable.
Protect Your Vision
Acer’s VisionCare suite of technologies are designed for protected your vision, especially when viewing a monitor for extended periods of time, such as a full workday. BlueLightShield minimises harmful blue light that cause eye strain as well as interfering with people’s sleep patterns, Flicker-Less eliminates screen flickering which can exacerbate fatigue caused by viewing the screen for long periods and ComfyView is an anti-glare finish that minimises reflections to make the screen easier to view.
Acer ZeroFrame
The V247Y features Acer’s ZeroFrame design, which slims down the bezels for a sleek, professional style. As well as helping the monitor to look nice, it also means it’s a great choice for multi-monitor set-ups, allowing for enhances productivity without thick, unsightly bezels between the screens.
IPS Panel
The V247Y also features an IPS panel, which allows it to produce more vivid colours and higher contrast, which helps content displayed on the screen to appear sharper; as well as supporting wider viewing angles which is great for when you’re collaborating with a colleague or showing a client what you’ve been working on.
Product Description | Acer V247Y bip - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class F | Energy Consumption per Year | 32 kWh | Power Consumption (On mode) | 22 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.274 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54 cm x 19.6 cm x 42.4 cm | Weight | 4.4 kg | Localisation | EMEA | Environmental Standards | TCO Certified Displays 8 EPEAT Bronze | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | IPS |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | ComfyView, Zero Frame, 3-sided bezeless, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 54 cm x 19.6 cm x 42.4 cm - with stand |
Weight | 4.4 kg |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort |
Mechanical | |
Tilt Angle | -5/+25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 1 x VGA cable |
MTBF | 30,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 21.8 kWh/1000h |
Power Consumption (Typical) | 15 Watt |
Power Consumption Stand by | 0.39 Watt |
Power Consumption Sleep | 0.27 Watt |
Power Consumption (Off Mode) | 0.27 Watt |
Dimensions & Weight (Shipping) | |
Shipping Weight | 6.5 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
EPEAT Compliant | EPEAT Bronze |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
