Find the perfect position for your viewing needs with this sturdy yet flexible design.
Product Description | Acer V277bi - V7 Series - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Energy Consumption per Year | 29 kWh | Power Consumption (On mode) | 20 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Brightness | 250 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.4 cm x 20.7 cm x 46.4 cm | Weight | 5.85 kg | Localisation | EMEA | Environmental Standards | ENERGY STAR Qualified EPEAT Bronze | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | 3-sided bezeless |
Colour | Black |
Dimensions (WxDxH) | 61.4 cm x 20.7 cm x 46.4 cm - with stand |
Weight | 5.85 kg |
Connectivity | |
Interfaces | HDMI , VGA |
Mechanical | |
Tilt Angle | -5/+25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 1 x VGA cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26.1 kWh/1000h |
Power Consumption (Typical) | 17 Watt |
Power Consumption Stand by | 0.42 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.4 cm - depth: 20.7 cm - height: 46.4 cm - weight: 5.85 kg , Without stand - width: 61.4 cm - depth: 6.6 cm - height: 36.7 cm - weight: 5 kg |
Environmental Standards | |
EPEAT Compliant | EPEAT Bronze |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
