Acer V6 Series V246HL 24" LED Full HD VGA DVI 3 year Wa...
Acer V6 Series V246HL 24"  LED Full HD VGA DVI 3 year Warranty Monitor
£131.59
Delivery:
Key features
  • Adaptable
  • Convincing
  • Prepared
  • Green focus
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
This stunning V246HL has some great features including DVI and replaces our bestselling low end 24" K series monitor. The V series is the next step up in terms of build quality within the Acer range and as such it carries a standard 3 year warranty for addtional peace of mind.
Main Features
  • Screen Size: 61 cm (24")
  • Screen Mode: Full HD
  • Response Time: 5 ms
  • Aspect Ratio: 16:9
  • Horizontal Viewing Angle: 170°
  • Vertical Viewing Angle: 160°
  • Adjustable Display Angle: Yes
  • Backlight Technology:LED
  • HDCP Supported: Yes
  • Maximum Resolution: 1920 x 1080
  • Standard Refresh Rate: 60 Hz
  • Colour Support: 16.7 Million Colours
  • Contrast Ratio: 100,000,000:1
  • Brightness: 250 cd/m²
  • Audio: Speakers
  • Interfaces/Ports: DVI VGA
  • Warranty: Standard 3 Years Warranty
Product Description Acer V246HLbmd - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 34 kWh
Power Consumption (On mode) 23 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.276 mm
Brightness 250 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Speakers Internal
Colour Black
Dimensions (WxDxH) 56.7 cm x 20.68 cm x 42.22 cm
Weight 3.9 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, ISO 9241-307, TCO Displays 6.0
Accessories
Accessories
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer V6 Series V246HL...
£131.59
