Packing powerful components into a petite, diamond-shaped chassis that can stand alone or snap onto the back of select Acer monitors, the Veriton N series aces your computing needs, while preserving precious space.
Product Description | Acer Veriton N4 VN4660G - compact PC - Core i5 8400T 1.7 GHz - 8 GB - 256 GB | Type | Personal computer - compact PC | Localisation | Region: United Kingdom | Processor | 1 x Intel Core i5 (8th Gen) 8400T / 1.7 GHz (3.3 GHz) (6-core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 9 MB | Cache Per Processor | 9 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | 1 x SSD 256 GB | Optical Storage | No optical drive | Graphics Controller | Intel UHD Graphics 630 | Networking | GigE, 802.11a, 802.11b/g/n, 802.11ac Wave 2, Bluetooth 5.0 | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 19.2 cm x 20.4 cm x 3.32 cm | Weight | 1.5 kg | Manufacturer Warranty | Limited warranty - 1 year - carry-in |
General | |
Type | Personal computer |
Product Form Factor | Compact PC |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8400T / 1.7 GHz |
Max Turbo Speed | 3.3 GHz |
Number of Cores | 6-core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel B360 |
Cache Memory | |
Installed Size | 9 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD |
Capacity | 1 x 256 GB |
Manufacturer | Kingston |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 630 |
Video Interfaces | VGA, DisplayPort |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111EPV |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Wireless-AC 9560 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0 |
Expansion / Connectivity | |
Interfaces | 2 x USB 2.0 , 3 x USB 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , DisplayPort , 1 x VGA |
Miscellaneous | |
Included Accessories | VESA mounting kit, 2x wireless aerials, ADP holder for VESA kit |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS |
Power | |
Device Type | Power adapter |
Power Provided | 65 Watt |
Operating System / Software | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in |
Dimensions & Weight | |
Width | 19.2 cm |
Depth | 20.4 cm |
Height | 3.32 cm |
Weight | 1.5 kg |
