Acer X1123H SVGA 3600 Lumens DLP Projector
£310.64
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Rich visuals in SVGA (800 x 600) resolution
  • 3,600 ANSI lumens for bright, clear images
  • Acer LumiSense content-aware technology & Bluelight Shield
  • Environment-friendly 15,000 hrs lamp life
  • Immerse yourself into 3D world with HDMI 3D
  • Portability: Portable
  • Stock Status: In Stock
Product codes
See images clearly from a distance with 3,600 lumens of brightness. Even in bright rooms, your presentations will shine as brilliantly as your ideas.
The contrast ratio is up to a whopping 20,000:1. Dynamic Black improves image contrast by analyzing onscreen content frame-by-frame and then dynamically adjusting lamp power to optimize black levels. The black can be extremely black and white is brilliant white.
Acer ColorBoost3D presents true-to-life colors through an optimized 6-segment color-wheel design, advanced lamp illumination technology, and powerful TI image processing. It can reduce brightness decay and color shift while displaying 2D and 3D content through enhancing color brightness, while also compensating color saturation and color temperature.
Product Description Acer X1123H - DLP projector - portable - 3D
Device Type DLP projector
3D Capable Yes (3D glasses sold separately)
Localisation United Kingdom, Europe
Brightness 3600 ANSI lumens
Contrast Ratio 20000:1 (dynamic)
Resolution SVGA (800 x 600)
Bulb type 190 Watt
Bulb life cycle Up to 15000 hour(s) - economic mode
Dimensions (WxDxH) 30 cm x 22 cm x 9.2 cm
Weight 2.25 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer X1123H SVGA 3600...
£310.64
