Acer X118 SVGA 3600 Lumens DLP Projector
£285.46
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Bright and vivid
  • Acer Dust Shield
  • Convenient and flexible
  • Portability: Portable
  • Stock Status: In Stock
Product codes
With high resolution, high brightness, high contrast and Acer Color technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance. Essential series projectors have features that make them easy to use.
Product Description Acer X118 - DLP projector - portable - 3D
Device Type DLP projector
3D Capable Yes (3D glasses sold separately)
Brightness 3600 lumens
Contrast Ratio 20000:1 (dynamic)
Resolution SVGA (800 x 600)
Native Aspect Ratio 4:3
Bulb type 203 Watt
Bulb life cycle Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB
Dimensions (WxDxH) 31.3 cm x 24 cm x 11.37 cm
Weight 2.7 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer X118 SVGA 3600 Lu...
£285.46
