Acer XF240HBMJDPR 24" 1920x1080 1ms VGA DVI HDMI LED Mo...
Acer XF240HBMJDPR  24" 1920x1080 1ms VGA DVI HDMI LED Monitor
£249.15
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Smoothed Gaming
Slide through your ride with AMD FreeSync. FreeSync technology eliminates screen tearing and minimises stuttering by syncing the display refresh rate with the frames output by your computer's display card. PC gaming doesn't get much smoother.
All the Right Moves
Acer XF Series monitors have the Acer ErgoStand stand with tilt, swivel, pivot and height adjustments so that you can always find that ideal viewing position. You can also detach the display panel for use with other VESA mounting devices as needed.
Acer XF240Hbmjdpr - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
51 kWh
Power Consumption (On mode)
35 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, DisplayPort, HDMI (MHL)
Display Position Adjustments
Screen Coating
Anti-glare
56.7 cm x 24.47 cm x 38.55 cm
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Acer XF240HBMJDPR 24"...
£249.15
