An incredible resolution and a curved 21:9 aspect ratio widescreen give you a truly panoramic view. Easy adjustments and special picture modes allow you to fully customize your viewing experience.
Product Description | Acer XR382CQK - LED monitor - curved - 37.5" | Device Type | LED-backlit LCD monitor - 37.5" | Energy Class | Class B | Energy Consumption per Year | 85 kWh | Power Consumption (On mode) | 58 W | Curved Screen | Yes | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | 3840 x 1600 at 75 Hz | Pixel Pitch | 0.229 mm | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Input Connectors | HDMI, HDMI (MHL), DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare | Colour | Silver | Image Colour Disclaimer | The displayed product image may be a different colour | Dimensions (WxDxH) - with stand | 89.688 cm x 30.9 cm x 46.177 cm | Weight | 10.9 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 37.5" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Horizontal Viewing Angle | 172 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture in picture, ambient light sensor, picture by picture, Acer EcoDisplay, 100% sRGB colour gamut, Zero Frame, daisy chain compatible, Flicker-Less technology, Blue Light Filter technology, DTS Sound, Adaptive-Sync technology |
Colour | Silver |
Dimensions (WxDxH) | 89.688 cm x 30.9 cm x 46.177 cm - with stand |
Weight | 10.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 7 Watt |
Connectivity | |
Interfaces | HDMI , MHL / HDMI , DisplayPort , DisplayPort output , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 60 |
Height Adjustment | 130 mm |
Miscellaneous | |
Included Accessories | Stand |
Cables Included | 1 x DisplayPort cable , 1 x SuperSpeed USB cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 58 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.48 Watt |
