Amazon All-New Echo Flex - White
FREE DELIVERY
£24.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Make any space a little smarter: this plug-in Echo device lets you get help from Alexa in more places in your home.
  • Alexa is always happy to help: manage your day and get instant information. Check weather and traffic on your way out.
  • Voice control your smart home: turn on lights, adjust thermostats, lock doors and more, with compatible connected devices.
  • Connect to external speakers for music: Echo Flex has a built-in mini speaker to hear Alexa, and can connect to external speakers via 3.5mm aux or Bluetooth to play music.
  • Built-in USB port: charge your phone or add an optional third-party accessory like a nightlight or motion sensor. (sold separately)
  • Keep your family in sync: use your Alexa devices like an intercom and talk to any room in the house with Drop In and Announcements.
  • Designed to protect your privacy: built with multiple layers of privacy protection and control, including a Microphone Off button that electronically disconnects the microphones.
  • Type: Smart Speaker
  • Compatible With: Alexa
  • Stock Status: Clearance
Product codes
Meet Echo Flex
Plug it in and use your voice to access instant information, add to your shopping basket, check the weather, make hands-free calls and control compatible smart home devices.
From down the hallway to around the corner, Alexa is happy to help make your day a little brighter. Use your voice to set timers or create daily reminders. Check the news, weather or traffic. Ask for sports scores, film screening times or restaurant opening hours.
Voice control more of your home
Manage compatible smart home devices using your voice. Switch on the lamp before getting out of bed, turn on the coffee machine on your way to the kitchen, or dim the lights from the sofa to watch a film.
Use Announcements to send voice messages to every room with a supported Echo device, or use Drop In as a two-way intercom between rooms. You can also make hands-free calls to almost anyone.
Alexa has skills
With tens of thousands of skills and counting, Alexa is always getting smarter. Skills are like apps and help you do more, such as play relaxing sounds or test your music knowledge. Just say, "Alexa, what are your top skills?"
Alexa and Echo devices are built with multiple layers of privacy protection. For example, Echo Flex has a Microphone Off button that electronically disconnects the microphones. You also have control over your voice recordings. You can view, hear or delete them at any time.
Product Description Amazon Echo Flex - smart speaker
Product Type Smart speaker
Localisation United Kingdom
Speaker Type Active
Interfaces Bluetooth, Wi-Fi
Intelligent Assistant Alexa - direct
Speaker Details Speaker - mono - active
Dimensions (WxDxH) 6.7 cm x 6.6 cm x 7.2 cm
Weight 166 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Amazon All-New Echo Fl...
£24.99
