Amazon Echo Dot (3rd Gen) - Black
FREE DELIVERY
£49.99
Colours:
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Uses the Alexa Voice Service to play music, provide information, read the news, set alarms, control smart home devices, and more using just your voice
  • Connects to speakers over Bluetooth or with the included audio cable to play music from Prime Music, Spotify, Pandora, iHeartRadio, and TuneIn
  • Includes a built-in speaker so it can work on its own as a smart alarm clock in the bedroom, an assistant in the kitchen, or anywhere you might want a voice-controlled computer
  • Hears you from across the room with far-field voice recognition, even while music is playing
  • Controls smart home devices like lights, switches, thermostats, and more with compatible connected devices from WeMo, Philips Hue, Samsung SmartThings, Nest, ecobee, and others
  • Always getting smarter and adding new features and skills
  • Type: Smart Speaker
  • Compatible With: Alexa
  • Stock Status: Clearance, Used Stock
Product codes
Echo Dot is a hands-free, voice-controlled device that uses the same far-field voice recognition as Amazon Echo. Dot has a small built-in speaker - it can also connect to your speakers over Bluetooth or with the included audio cable. Dot connects to the Alexa Voice Service to play music, provide information, news, sports scores, weather, and more - instantly.
Echo Dot can hear you from across the room, even while music is playing. When you want to use Echo Dot, just say the wake word "Alexa" and Dot responds instantly. If you have more than one Echo or Echo Dot, Alexa responds intelligently from the Echo device you're closest to with ESP (Echo Spatial Perception).
Product Description Amazon Echo Dot - 3rd Generation - smart speaker
Product Type Smart speaker
Localisation United Kingdom
Speaker Type Active
Interfaces Bluetooth, Wi-Fi
Intelligent Assistant Compatible Alexa
Streaming Services Pandora, NPR, Spotify, SiriusXM internet radio, Amazon Music, Audible
Speaker Details Speaker - mono - active
Colour Charcoal
Dimensions (WxDxH) 9.9 cm x 9.9 cm x 4.3 cm
Weight 300 g
Manufacturer Warranty 1-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: DVFD 041278
£17.58
product
Ref: DVFD 041278
Accessories
Packaging
Functional
Software
Manuals
£17.58
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Amazon Echo Dot (3rd G...
£49.99
