Amazon Echo Dot (3rd Gen) - Charcoal Fabric
FREE DELIVERY
£49.99
Colours:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Our most popular smart speaker: now with a fabric design and improved speaker for richer and louder sound.
  • Voice control your music: stream songs from Amazon Music, Apple Music, Spotify, TuneIn and others. You can also listen to audiobooks from Audible.
  • Bigger, better sound: pair with a second Echo Dot for rich, stereo sound. Fill your home with music with compatible Echo devices in different rooms.
  • Ready to help: ask Alexa to play music, answer questions, read the news, check the weather, set alarms, control compatible smart home devices and more.
  • Type: Smart Speaker
  • Compatible With: Alexa
  • Stock Status: Clearance
Product codes
  • Connect with others: call almost anyone hands free. Instantly drop in on other rooms in your home or make an announcement to every room with a compatible Echo device.
  • Alexa has skills: with tens of thousands of skills, Alexa is always getting smarter and adding new skills like tracking fitness, playing games and more.
  • Voice control your smart home: turn on lights, adjust thermostats, lock doors and more, with compatible connected devices.
  • Designed to protect your privacy: built with multiple layers of privacy protection and control, including a Microphone Off button that electronically disconnects the microphones.
  • Ring: you can now use your Echo device to receive doorbell notifications and motion alerts
Meet the all-new Echo Dot Our most popular Echo is now even better.
With a new speaker and design, Echo Dot is a voice-controlled smart speaker with Alexa that's perfect for any room. Just ask for music, news, information and more. You can also call almost anyone, and control compatible smart home devices with your voice.
"Alexa, play popular songs."
Use your voice to play a song, artist or genre through Amazon Music, Apple Music, Spotify, TuneIn and others. With compatible Echo devices in different rooms, you can fill your whole home with music. Also listen to Audible and radio stations, or pair with Fire TV to voice-control films and entertainment.
Always ready to help
Make your life easier at home. Use your voice to set timers, add items to lists, or create calendar events and reminders. You can also check the news, weather or traffic, or ask for sports scores, cinema listings, restaurant hours or information.
Voice-control your smart home
Switch on the lamp before getting out of bed or dim the lights from the sofa to watch a film—all without lifting a finger. Control multiple devices with a single voice command, like locking the doors and turning off the lights at night.
Connect with others
You can call almost anyone hands-free, including UK mobile and residential numbers (from UK only. Emergency calling not supported), other Echo devices, the Alexa app and Skype. You can also link Alexa with your UK EE mobile phone account to ask Alexa to make and answer your mobile calls. With the Drop In feature enabled for room-to-room calling, quickly connect with Echo devices in your home. Let your household know when dinner is ready, ask someone for help with a chore or remind the kids to go to sleep—without having to raise your voice.
Alexa has skills
Alexa has tens of thousands of skills and counting. Skills are like apps and help you do more, such as playing True or False, tracking your fitness with Fitbit or falling asleep to rain sounds. Create your own personal skills and custom responses with Alexa Skill Blueprints. Just say "Alexa, help me get started with skills". New skills are being added all the time. Discover skills in the Skills section of the Alexa App or visit the Skills Store.
Alexa and Echo devices are built with multiple layers of privacy protection. For example, Echo Dot has a Microphone Off button that electronically disconnects the microphones. You also have control over your voice recordings. You can view, hear or delete them at any time.
Product Description Amazon Echo Dot - 3rd Generation - smart speaker
Product Type Smart speaker
Speaker Type Active
Interfaces Bluetooth, Wi-Fi
Intelligent Assistant Alexa - direct
Streaming Services NPR, Spotify, Amazon Music, Audible
Speaker Details Speaker - mono - active
Colour Charcoal
Dimensions (WxDxH) 9.9 cm x 9.9 cm x 4.3 cm
Weight 300 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Amazon Echo Dot (3rd G...
£49.99
