Echo Dot is a hands-free, voice-controlled device that uses the same far-field voice recognition as Amazon Echo. Dot has a small built-in speaker - it can also connect to your speakers over Bluetooth or with the included audio cable. Dot connects to the Alexa Voice Service to play music, provide information, news, sports scores, weather, and more - instantly.
Echo Dot can hear you from across the room, even while music is playing. When you want to use Echo Dot, just say the wake word "Alexa" and Dot responds instantly. If you have more than one Echo or Echo Dot, Alexa responds intelligently from the Echo device you're closest to with ESP (Echo Spatial Perception).
Product Description | Amazon Echo Dot - 3rd Generation - smart speaker | Product Type | Smart speaker | Speaker Type | Active | Interfaces | Bluetooth, Wi-Fi | Intelligent Assistant | Alexa - direct | Streaming Services | NPR, Spotify, Amazon Music, Audible | Speaker Details | Speaker - mono - active | Colour | Charcoal | Dimensions (WxDxH) | 9.9 cm x 9.9 cm x 4.3 cm | Weight | 300 g | Manufacturer Warranty | 1-year warranty |
General | |
Microphone | 4 microphones array |
Enclosure Colour | Charcoal |
Speaker System | |
Multiroom | Yes |
Amplifier | Integrated |
Interfaces | Bluetooth, IEEE 802.11a/b/g/n |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Internet Streaming Services | NPR, Spotify, Amazon Music, Audible |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Internet of Things (IoT) Hub | Integrated |
Intelligent Assistant Compatible | Alexa |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Woofer driver - 1.6" |
Connections | |
Connector Type | Audio line-out (mini-phone stereo 3.5 mm) |
Miscellaneous | |
Included Accessories | AC power adaptor |
Power | |
Power Source | AC power adapter |
Dimensions & Weight | |
Width | 9.9 cm |
Depth | 9.9 cm |
Height | 4.3 cm |
Weight | 300 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
