Amazon Echo Dot White
FREE DELIVERY
Colours:
Key features
  • Uses the Alexa Voice Service to play music, provide information, read the news, set alarms, control smart home devices, and more using just your voice
  • Connects to speakers over Bluetooth or with the included audio cable to play music from Prime Music, Spotify, Pandora, iHeartRadio, and TuneIn
  • Includes a built-in speaker so it can work on its own as a smart alarm clock in the bedroom, an assistant in the kitchen, or anywhere you might want a voice-controlled computer
  • Hears you from across the room with far-field voice recognition, even while music is playing
  • Controls smart home devices like lights, switches, thermostats, and more with compatible connected devices from WeMo, Philips Hue, Samsung SmartThings, Nest, ecobee, and others
  • Always getting smarter and adding new features and skills
Product codes
Echo Dot is a hands-free, voice-controlled device that uses the same far-field voice recognition as Amazon Echo. Dot has a small built-in speaker - it can also connect to your speakers over Bluetooth or with the included audio cable. Dot connects to the Alexa Voice Service to play music, provide information, news, sports scores, weather, and more - instantly.
Echo Dot can hear you from across the room, even while music is playing. When you want to use Echo Dot, just say the wake word "Alexa" and Dot responds instantly. If you have more than one Echo or Echo Dot, Alexa responds intelligently from the Echo device you're closest to with ESP (Echo Spatial Perception).
Amazon Echo Dot - 2nd Generation - smart speaker
Smart speaker
7 microphones array
Speaker Type
Active
Bluetooth, Wi-Fi
Platform
Belkin WeMo, Hue, Insteon, Lutron, Nest, SmartThings, ecobee, TP-Link, Wink, hive, tado
Intelligent Assistant Compatible
Alexa
Streaming Services
Pandora, Spotify, TuneIn, iHeartRadio, Amazon Music Unlimited
Speaker Details
Speaker - mono - active
8.4 cm x 8.4 cm x 3.2 cm
Dimensions - Diameter
8.4 cm
163 g
90 days warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
