Amazon Echo Plus (2nd Gen) - Black
FREE DELIVERY
£69.99
Colours:
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Echo Plus has a built-in Zigbee hub to easily set up and control your compatible smart home devices, and an improved sound for streaming music.
  • Premium speakers powered by Dolby play 360° audio with crisp vocals and dynamic bass response. You can also adjust equaliser settings within the Alexa app.
  • Just ask Alexa to play music, read the news, check weather forecasts, set alarms and timers, control compatible smart home devices, call anyone with an Echo device, the Alexa App or Skype, and more.
  • Set up your smart home without a separate hub. Ask Alexa to control compatible Zigbee smart lights, plugs and more. Echo Plus also includes a built-in temperature sensor.
  • Type: Smart Speaker
  • Compatible With: Alexa
  • Stock Status: Clearance
Product codes
  • Ask Alexa for a song, artist or genre from Amazon Music, Apple Music, Spotify, TuneIn and more. With multi-room music, you can play music on your compatible Echo devices in different rooms.
  • Connect with others: call almost anyone hands free. Instantly drop in on other rooms in your home or make an announcement to every room with a compatible Echo device.
  • With seven microphones, beam-forming technology and noise cancellation, Echo Plus hears you from any direction - even while music is playing.
  • Designed to protect your privacy. Built with multiple layers of privacy protection and control, including a Microphone Off button that electronically disconnects the microphones.
  • You can now use your Echo device to receive doorbell notifications and motion alerts.
Meet the all-new Echo Plus
Echo Plus features a premium speaker for powerful 360° sound, and a built-in Zigbee smart home hub and temperature sensor. Play music, ask questions, call almost anyone, or get information, news, sports scores, weather and more. With the built-in hub, starting your smart home is easy.
The simple way to start your smart home
Echo Plus connects to and controls smart lights, plugs, switches and more. Just power on compatible products and say, "Alexa, discover my devices." Echo Plus will automatically detect and set up those devices so you can control them with your voice. This simple setup process works with dozens of compatible smart home devices that use Zigbee. Echo Plus also supports every Works with Alexa smart home device.
Alexa and Echo devices are built with multiple layers of privacy protection. For example, Echo Plus has a Microphone Off button that electronically disconnects the microphones. You also have control over your voice recordings. You can view, hear or delete them at any time.
Always read to help
Make your life easier at home. Use your voice to set timers, add items to lists or create calendar events and reminders. You can also check the news, weather or traffic, or ask for sports scores, film showtimes, restaurant hours or information.
Voice-control your music
Echo Plus has a new premium speaker design with Dolby Processing, engineered for high-quality audio. Use your voice to ask for any song, artist or genre from Amazon Music, Apple Music, Spotify, TuneIn, and others, and play music across compatible Echo devices throughout your home. You can also listen to Audible, radio stations and more.
Connect with others
You can call almost anyone hands-free, including UK mobile and residential numbers (from UK only. Emergency calling not supported), other Echo devices, the Alexa app and Skype. You can also link Alexa with your UK EE mobile phone account to ask Alexa to make and answer your mobile calls. With the Drop In feature enabled for room-to-room calling, quickly connect with Echo devices in your home. Let your household know when dinner is ready, ask someone for help with a chore or remind the kids to go to sleep—without having to raise your voice.
Alexa has skills
Alexa has tens of thousands of skills and counting. Skills are like apps and help you do more, such as playing True or False, tracking your fitness with Fitbit or falling asleep to rain sounds. Create your own personal skills and custom responses with Alexa Skill Blueprints. Just say "Alexa, help me get started with skills". New skills are being added all the time. Discover skills in the Skills section of the Alexa App or visit the Skills Store.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Amazon Echo Plus (2nd...
£69.99
