Amazon Echo Spot White
STYLISH, COMPACT ECHO WITH A SCREEN
£119.98
Colours:
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Echo Spot is designed to fit anywhere in your home
  • Echo Spot connects to Alexa, a cloud-based voice service to play music, read the news, answer questions, set music alarms, control smart home, and more
  • Adjust the treble, mid, and bass levels with your voice
  • Type: Smart Display
  • Compatible With: Alexa
  • Stock Status: In Stock
Product codes
Echo Spot brings you everything you love about Alexa, in an all-new stylish and compact design that can show you things. Just ask to see the weather, get the news with a video flash briefing, set a music alarm (Amazon Music, Spotify & TuneIn supported), see lyrics with Amazon Music, see your calendar, browse and listen to Audible audiobooks, and more. Personalise your Spot with a collection of clock faces to suit your style or set a photo background from Prime Photos. Plus, make calls to friends and family between supported Echo devices or the Alexa App, or make video calls to anyone with an Echo Spot, Echo Show or the Alexa App.
Echo Spot features second-generation far-field technology with four microphones, beam-forming technology and enhanced noise cancellation, so it can hear you from across the room—even while music is playing. If you have more than one Echo, Alexa responds intelligently from the Echo you're closest to with ESP (Echo Spatial Perception).
Product Description Amazon Echo Spot - smart display - wireless
Product Type Smart display
Features 4 microphones array
Speaker Type Active
Amplifier Integrated
Display LCD - 2.5" - 480 x 480
Camera 0.48 Megapixel
Interfaces Bluetooth, Wi-Fi
Platform Belkin WeMo, Hue, Nest, SmartThings, ecobee, TP-Link, Wink
Intelligent Assistant Compatible Alexa
Streaming Services Pandora, Spotify, SiriusXM internet radio, iHeartRadio, Apple Music, Amazon Music, Audible
Speaker Details Speaker - mono - 2 Watt - active
Colour White
Dimensions (WxDxH) 10.4 cm x 9.1 cm x 9.7 cm
Weight 419 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£119.98
