Meet Kindle, now with a built-in adjustable front light so you can read indoors, outdoors and at more times of day. Purpose-built for reading, Kindle features a glare-free touchscreen display that reads like printed paper, even in direct sunlight.
Product Description | Amazon Kindle - 10th generation - eBook reader - 4 GB - 6" | Product Type | eBook reader | Display | 6" monochrome E Ink (167 ppi) - touchscreen | Storage | 4 GB | Wireless Connectivity | Bluetooth, 802.11b/g/n | Supported Text Formats | DOCX, PDF, TXT, DOC, HTML, PRC (Mobipocket), AZW, AZW3, MOBI | Supported Still Image Formats | GIF, JPEG, PNG | Battery Run Time | Up to 28 day(s) | Dimensions (WxDxH) | 11.3 cm x 0.87 cm x 16 cm | Weight | 174 g | Colour | Black | Pricing Type | With Special Offers | Manufacturer Warranty | 1-year warranty |
General | |
Display | |
Type | 6" monochrome E Ink |
Resolution | (167 ppi) |
Colour Depth | 16 grey levels (4-bit) |
Touchscreen | Yes |
Features | Anti-glare, adjustable front light |
Memory | |
Storage | 4 GB |
Communications | |
Security Protocols & Features | WEP, WPA, WPA2, WPS |
EBook Reader | |
Input Device | |
Type | Touch-screen |
Expansion and Connectivity | |
Interfaces | 1 x USB 2.0 |
Battery | |
Recharge Time | 4 hour(s) |
Miscellaneous | |
Colour | Black |
Included Accessories | Power adapter |
Cables Included | USB charge cable |
Dimensions & Weight | |
Width | 11.3 cm |
Depth | 0.87 cm |
Height | 16 cm |
Weight | 174 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
