AMD Firepro 2460 512MB DDR3
Key features
  • Low profile half length form factor
  • Quad DisplayPort and DVI output
  • Lower board power
  • Hardware acceleration of DirectX 11 and OpenGL 4.1
  • PCI Express 2.1 compliant
Product codes
The ATI FirePro 2460 Multi-View is the first low profile, quad mini DisplayPort capable solution available - allowing users to expand their field of view across four large (30") high resolution displays.
Featuring AMD Eyefinity multi-display technology, the ATI FirePro 2460 is an ideal solution for anyone whop needs the space saving advantages of a small form-factor PC but also wants the advantages of high quality, high resolution displays. With support for up to 16 megapixels of display data, the ATI FirePro 2460 allows the busiest of multi monitor users to have enough display real estate to manage all of their needs.
As the first low profile, passively cooled, quad mini DisplayPort capable solution, the ATI FirePro 2460 is designed for completely silent running to help prolong life.
ATI FirePro 2460 can support a stretched desktop across four screens, allowing applications to treat this desktop as a single large surface that displays content virtually seamlessly across all four displays.
Product Description AMD FirePro 2460 Multi-View - graphics card - FirePro 2460 - 512 MB
Device Type Graphics card - low profile
Bus Type PCI Express 2.1 x16
Graphics Engine AMD FirePro 2460
Memory 512 MB GDDR5
Max Resolution 2560 x 1600
Max Resolution Details DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / VGA: 1920 x 1200
Max Monitors Supported 4
Interfaces 4 x Mini DisplayPort , 4 x DVI - with adapter
API Supported DirectX 11, OpenGL 4.4
Fanless Yes
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
