The Super Slim and WiFi Connected RoboVac
Eliminate Vacuuming Chores
RoboVac takes on dust busting around your home so you don’t have to. Multiple cleaning modes and auto clean scheduling ensure an effortless, thorough clean while you relax. And Amazon Alexa compatibility* means you can enjoy clean floors by just saying "Alexa, ask RoboVac to start cleaning."
Improved Cleaning
Refined from the inside and out to provide quiet vacuuming with zero hassle, RoboVac cleans with the equivalent sound of an operating microwave, and is only 2.85" tall to clean under low hanging furniture with ease.
Lean, Mean, Cleaning Machine
RoboVac may be super slim, but it’s packed with a 3 point cleaning system, BoostIQ technology, and up to 1300Pa of suction power to ensure your floors and carpets are clear of all dirt, dust, and crumbs.
Cleans Further
A larger 0.6L dustbin allows RoboVac to pick up more dirt and dust to take full advantage of 100 minutes** of continuous cleaning and without the need for emptying in between.
Premium Components
The anti scratch tempered glass cover provides a sleek look and superior protection for RoboVac, while the triple layer high performance filter achieves a better clean for your home.
For Optimal Use:
Note: *Compared to previous eufy RoboVac models.
* Standard suction mode (hardwood floors) provides approx. 100 minutes of cleaning. BoostIQ mode (carpeting) provides approximately 60 minutes of cleaning. ** Alexa devices sold separately.
Product Description | Eufy RoboVac 15C - vacuum cleaner - robotic - black | Product Type | Vacuum cleaner | Cleaner Type | Robotic | Compatible Floor Type | General purpose | Cleaning Method | Dry | Control Type | Electronic | Control Elements | Push button | Communications Technology | Wi-Fi | Intelligent Assistant | Google Assistant, Alexa | Dust Collection | Bagless | Operating Autonomy | 100 min | Sound Pressure Level (SPL) | 55 dB | Colour | Black | Dimensions (WxDxH) | 7.2 cm | Manufacturer Warranty | 1 year |
General | |
Vacuum Cleaner Type | General purpose |
Compatible Floor Type | Carpet, hard floor |
Filter Type | High Performance filter |
Dust Capacity | 0.6 litre |
Suction Pressure | 1.3 kPa |
Room Navigation | Yes |
Special Features | Edge cleaning, sensor technology |
Colour | Black |
Settings, Controls & Indicators | |
Scheduling Presets | Yes |
Smartphone Compatible | Yes |
Internet of Things (IoT) | |
Miscellaneous | |
Included Tools | Motorized brush, side brush (2x) |
Included Accessories | Remote control , Cleaning tool |
Power | |
Power Type | Rechargeable batteries |
Battery | Lithium Ion |
Battery Voltage | 14.4 V |
Battery Capacity | 2600 mAh |
Full Charge Time | 6 hrs |
Dimensions & Weight | |
Height | 7.2 cm |
Manufacturer Warranty | |
Warranty | 1 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
