Innovative eufy technology has doubled the suction power to achieve a deeper level of clean. Two turbines, each generating up to 2000 Pa of intense suction, efficiently increases cleaning power. Leave the floors to RoboVac X8 Series so you can focus on the more important things. Double down on power, double down on life.
Product Description | Eufy RoboVac X8 - vacuum cleaner - robotic | Product Type | Vacuum cleaner | Cleaner Type | Robotic | Compatible Floor Type | General purpose | Cleaning Method | Dry | Communications Technology | Wi-Fi | Intelligent Assistant | Google Assistant, Alexa | Dust Collection | Bagless | Operating Autonomy | 180 min | Sound Pressure Level (SPL) | 60 dB | Dimensions (WxDxH) | 34.5 cm x 34.5 cm x 9.72 cm | Weight | 3.5 kg | Manufacturer Warranty | 1 year |
General | |
Vacuum Cleaner Type | General purpose |
Dust Capacity | 0.6 litres |
Suction Pressure | 4 kPa |
Room Navigation | Yes |
Special Features | Adjustable suction |
Pet Hair Removal | Yes |
Settings, Controls & Indicators | |
Smartphone Compatible | Yes |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Power | |
Power Type | Rechargeable batteries |
Battery | Lithium Ion |
Battery Voltage | 24 V |
Battery Capacity | 5200 mAh |
Full Charge Time | 5 hrs |
Dimensions & Weight | |
Width | 34.5 cm |
Depth | 34.5 cm |
Height | 9.72 cm |
Weight | 3.5 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 42 cm |
Depth (Shipping) | 46.2 cm |
Height (Shipping) | 16.3 cm |
Manufacturer Warranty | |
Warranty | 1 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
