eufy Security features a powerful battery that provides long-lasting power for round-the-clock security. To prevent your playful pets from accidentally triggering the motion sensor, you can adjust the sensitivity so that it only triggers when human-sized intruders are detected.
Product Description | Eufy Security - motion sensor - Wi-Fi - white | Product Type | Motion sensor | Power Source | Battery | Connectivity | Wireless - Wi-Fi | Adjustments | Detection sensitivity | Colour | White | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 5.62 cm x 2.2 cm x 5.62 cm |
General | |
Connectivity Technology | Wireless |
Features | In app notification |
Motion Sensor | |
Detection Range | 9.14 m |
Detection Angle | 100 degree(s) |
Battery | |
Battery Included | Yes |
Required Qty | 1 |
Battery Lifetime | 2 years |
Miscellaneous | |
Colour | White |
Dimensions & Weight | |
Width | 5.62 cm |
Depth | 2.2 cm |
Height | 5.62 cm |
Weight | 70 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.2 cm |
Shipping Depth | 10.5 cm |
Shipping Height | 3.8 cm |
Shipping Weight | 220 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
