To Hold or to Fold
The magnetic portable charger holds your iPhone 13/12 in place while charging and combines it with a kickstand that can unfold to function as a phone stand.
Two-Way Charge
Consisting of USB-C input and output ports, you can now quickly recharge the portable charger or power up any compatible USB-C devices.
Safety First
Anker's exclusive MultiProtect technology comes with advanced safety features like temperature control, overload protection, and more to let you charge with zero worries.
Compatibility:
iPhone 13 / iPhone 13 Pro / iPhone 13 Pro Max / iPhone 12 / iPhone 12 Pro / iPhone 12 Pro Max with a magnetic phone case.
Product Description | Anker 622 (MagGo) wireless charging stand / power bank - 24 pin USB-C - 7.5 Watt | Product Type | Wireless charging stand / power bank | Dimensions (WxDxH) | 6.55 cm x 10.5 cm x 1.28 cm | Weight | 140 g | Colour | Dolomite white | Output Connector Type | 24 pin USB-C - on cable: USB-C | Wireless Charging | Yes | Battery | 5000 mAh | Power Provided | 7.5 Watt | Cables | USB-C to USB-C cable - 60 cm | Manufacturer Warranty | 2-year warranty | Designed For | Apple iPhone 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max |
General | |
Designed For | Mobile phone |
Width | 6.55 cm |
Depth | 10.5 cm |
Height | 1.28 cm |
Weight | 140 g |
Enclosure Colour | Dolomite white |
Power Device | |
Input Connectors | 24 pin USB-C |
Output connectors | 24 pin USB-C |
Detachable Cable Connector Type | USB-C |
MagSafe Compatibility | Yes |
Features | Built-in magnets, built-in foldable stand, MultiProtect, 7.5W wireless output |
Battery | |
Capacity | 5000 mAh |
Features | Battery level indicator |
Miscellaneous | |
Cables Included | USB-C to USB-C cable - 60 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
Customer return - item has been opened but is in excellent condition
Ref: GSR2 046517 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£38.58
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
