Seamless Touch Controls
Browse your entertainment with pinpoint precision. Apollo's transparent touch panel gives you the power to navigate menus and more with ease, directly from the device.
Clear Picture
See every detail of your favorite movies, shows, games, and more in remarkable clarity with Apollo's 200 ANSI lumen DLP lamp and expansive 100" image.
Enhanced Playtime
Apollo delivers 4 hours of video playtime on a single charge, enough for a midnight Netflix binge.
Android 7.1
Download and stream YouTube, Netflix, Hulu, and more straight to Apollo without the need to connect additional devices.
Note: Copyrighted content from Hulu, Netflix, and similar services CAN NOT be mirrored or screencast. Download and use the apps directly through Apollo to view copyrighted content from these providers. Chromecast is not supported
Product Description | Nebula Capsule II - DLP projector - 802.11a/b/g/n wireless / Bluetooth 4.2 - black | Device Type | DLP projector - 720p | Colour | Black | Built-in Devices | Speaker, lithium-polymer battery (9700 mAh) | Brightness | 200 ANSI lumens | Contrast Ratio | 600:1 | Resolution | 1280 x 720 | Native Aspect Ratio | 16:9 | Bulb type | RGB LED | Video Input | IEEE 802.11a/b/g/n wireless / Bluetooth 4.2 | Storage Capacity | 8 GB | Speakers | Speaker(s) - integrated | Power Consumption Operational | 20 Watt | Dimensions (WxDxH) | 8 cm x 8 cm x 15 cm | Weight | 680 g | Manufacturer Warranty | 1-year warranty |
General | |
Networking | 802.11a/b/g/n, Bluetooth 4.2 |
Internet Streaming Services | Chromecast |
Enclosure Colour | Black |
Projector | |
Image Size | 51 cm - 254 cm |
Projection Distance | 0.58 m - 3.08 m |
Throw Ratio | 1.3:1 |
Resolution | WXGA - 1280 x 720 |
Features | Auto focus, Bluetooth speaker mode |
Video Input | |
Video Interfaces | HDMI |
LAN and Wireless Image Transferring Protocols | IEEE 802.11b, IEEE 802.11g, IEEE 802.11a, IEEE 802.11n, Bluetooth 4.2 |
Media Player | |
Processor | ARM Cortex-A53 Quad-Core |
RAM | 2 GB |
Operating System | Android TV 9.0 |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 8 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm |
Miscellaneous | |
Included Accessories | Wireless remote control, power adapter |
Cables Included | 1 x USB-C charge cable |
Compliant Standards | FCC Part 15, FCC, RoHS, BQB, CP65, Directive 2014/53/EU |
Power | |
Power Source | Battery |
Power Consumption Stand by | 0.5 Watt |
Battery | |
Capacity | 9700 mAh |
Run Time (Up To) | 3 hour(s) |
Recharge Time | 2.5 hours |
Dimensions & Weight | |
Width | 8 cm |
Depth | 8 cm |
Height | 15 cm |
Weight | 680 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 15 - 85% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
