Portable Projector
Marketing description is not available.
Product Description | Nebula Vega Portable - DLP projector - portable - 802.11a/b/g/n/ac wireless / Bluetooth 4.2 | Device Type | DLP projector - 1080p | Brightness | 500 ANSI lumens | Resolution | Full HD (1920 x 1080) | Native Aspect Ratio | 16:9 | Bulb type | LED | Bulb life cycle | Up to 30000 hour(s) | Video Input | IEEE 802.11a/b/g/n/ac wireless / Bluetooth 4.2 - MPEG-4, AVI, WMV, MOV, DAT, MKV | Speakers | Speaker(s) - integrated | Dimensions (WxDxH) | 19.2 cm x 19.2 cm x 5.9 cm | Weight | 1.4 kg | Manufacturer Warranty | 1-year warranty |
General | |
Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Projector | |
Image Size | 318 cm |
Resolution | Full HD - Full HD (1920 x 1080) |
Bulb type | LED |
Controls & Adjustments | Keystone correction |
Features | MP3 playback, OGG playback, FLAC playback, auto focus, WMA playback, HDR10 compatibility, Dolby Digital Plus |
Lens | |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -40 / +40 |
Horizontal Keystone Correction | -40 / +40 |
Video Input | |
Video Interfaces | HDMI |
Digital Video Format | MPEG-4, AVI, WMV, MOV, DAT, MKV |
LAN and Wireless Image Transferring Protocols | IEEE 802.11b, IEEE 802.11g, IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Media Player | |
Processor | ARM Cortex-A53 |
Graphics Processing Unit | ARM Mali-G31 |
Operating System | Android TV 9.0 |
Speakers | |
Type | Integrated |
Sound Output Mode | Stereo |
Output Power / Channel | 4 Watt |
Speakers | 2 x right / left channel |
Expansion / Connectivity | |
Interfaces | 1 x HDMI - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB (power only) |
Miscellaneous | |
Included Accessories | Wireless remote control, PD charger |
Cables Included | 1 x USB-C cable |
Battery | |
Capacity | 20000 mAh |
Run Time (Up To) | 3 hour(s) |
Recharge Time | 3 hours |
Dimensions & Weight | |
Width | 19.2 cm |
Depth | 19.2 cm |
Height | 5.9 cm |
Weight | 1.4 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Sound Emission | 30 dB |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
