We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Anker 535 portable power station, portable generator 512 Wh (PowerHouse 512 Wh), 500 W 9-port outdoor generator with 4 AC outlets, 60 W USB-C PD output, LED light for camping, RV, emergencies, and more.
Long-Lasting Portable Power Station With a 10-Year Lifespan: With our proprietary long-lasting technology InfiniPower™, combined with LiFePO4 batteries, ultra-durable electronic components, a smart temperature control system that monitors temperature up to 100 times per second, and impact-resistant structural design, Anker 535 PowerHouse is built to last over a decade, even with everyday use.
5-Year Full-Device Warranty: Instead of the average 2 years, Anker 535 Portable Power Station is designed to reliably power your devices every day for 10 years. Additionally, it offers a superior 5-year full-device warranty for a guaranteed, worry-free experience.
Extra USB-C Port: Recharge to 80% in under 2.5 hours via the in-box adapter and a USB-C port. Time to get rid of bulky adapters because charging your laptop at fast speeds only requires a single cable.
7 Ports for All: The power station has all the ports you need to charge your devices and appliances. It is equipped with 2 AC ports, 3 USB-A ports, a USB-C port, and a car outlet. -
All-Round Capacity: With a 512Wh capacity, the power station is an all-round solution to charge all your necessities. Seamlessly power a heater, portable fridge, lamp, and TV.
What You Get: Anker 535 Portable Power Station (PowerHouse 512Wh), 120W adapter, car charging cable, welcome guide, our worry-free 5-Year warranty, and friendly customer service.
Product Description | Anker PowerHouse 535 - portable power station - 716 Watt - LiFePO4 - 32000 mAh - 512 Wh | Device Type | Portable power station - external | Weight | 7.6 kg | Output Voltage | AC 220-240/ DC 5 / 9/ 12/ 15/ 20 V | Power Capacity | 716 Watt | Input Connectors | 2 x power DC jack, 24 pin USB-C | Output connectors | 3 x 9 pin USB Type A - 5 V 2.4 A 12 W , 2 x power - 230 V 2.27 A 500 W , 1 x automobile cigarette lighter - 12 V 10 A 120 W , 1 x 24 pin USB-C 3 A 60 W | Battery | Lithium iron phosphate - 32000 mAh - 512 Wh | Included Accessories | Power adapter | Dimensions (WxDxH) | 29.2 cm x 25.1 cm x 18.8 cm | Manufacturer Warranty | 5-year warranty |
General | |
Power Device | |
Input Voltage Range | DC 11 - 28 V / 5 / 9 / 15 / 20 V |
Power Output Connectors Details | 3 x 9 pin USB Type A - 5 V 2.4 A 12 W , 2 x power - 230 V 2.27 A 500 W , 1 x automobile cigarette lighter - 12 V 10 A 120 W , 1 x 24 pin USB-C 3 A 60 W |
Battery | |
Technology | Lithium iron phosphate |
Voltage Provided | 16 V |
Capacity | 32000 mAh - 512 Wh |
Max Recharge Cycles | 3000 |
Miscellaneous | |
Cables Included | Car power cable - external |
Features | LCD display, drop-resistant, LED lamp, overcurrent protection, overload protection, 60W power delivery, PowerIQ technology, PowerIQ 3.0 technology, solar panel compatible, LED display, PowerIQ 3.0, SOS mode |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 40 °C |
Dimensions & Weight | |
Width | 29.2 cm |
Depth | 25.1 cm |
Height | 18.8 cm |
Weight | 7.6 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 8.87 kg |
