We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Two built-in microphones with uplink noise cancellation boost clarity by recognizing your voice and filtering out ambient noises to ensure you sound crystal-clear even in noisy spaces. Stereo calls further enhance call quality by allowing you to hear the other person's voice in both earbuds.
Graphene-coated drivers oscillate precisely, enabling Liberty Air to reproduce highly-accurate sound. Every detail of the music, from the deepest bass, to the brightest mids, and lush treble is delivered with extraordinary clarity and no distortion.
The latest Bluetooth 5.0 technology and a FPC antenna create a rock-solid connection for skip-free music. One-Step Pairing ensures that after the initial setup is complete, Liberty Air will automatically connect to your device the moment it's removed from the charging case.
A seamlessly concealed sensor in both the earbuds allows you to effortlessly answer calls or adjust music without reaching for your phone.
Product Description | Soundcore Liberty Air 2 - true wireless earphones with mic | Product Type | True wireless earphones - Bluetooth | Colour | White | Headphones Form Factor | In-ear | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz | Impedance | 16 Ohm | Max Input Power | 5 mW | Microphone Active Noise Cancelling | Yes | Microphones Included | 4 | Controls | Volume, power on/off, answer/end, play/pause, next/previous track, reject call, voice assistant | Manufacturer Warranty | 18 months warranty |
General | |
Product Type | True wireless earphones - Bluetooth - wireless |
Colour | White |
Features | HearID Technology, Diamond-Coated Driver |
Protection | IPX5, water-resistant |
Max Operating Distance | 10 m |
Audio Output | |
Connectivity Technology | Wireless |
Bluetooth Audio Codec | SBC, AAC, aptX |
Bluetooth Profiles | Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Frequency Response | 20 - 20000 Hz |
Total Harmonic Distortion (THD) | 1% |
Diaphragm | 6 mm |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Miscellaneous | |
Included Accessories | Charging case (500 mAh), 5 pairs of ear tips (XS, small, medium, large, XL), USB-C charging cable |
Power | |
Battery | Headphone battery rechargeable |
Included Qty | 2 |
Capacity | 55 mAh |
Run Time (Up To) | 7 hour(s) |
Run Time Details | Continuous playback: up to 7 hours , Continuous playback (with included charging case): up to 28 hours |
Recharge Time | 2 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 18 months |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
