We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Up to 40 Hours of Playtime
A single charge gives you a full 7 hours of listening, while the charging case extends that to 40 hours. When you’re in a rush and need power fast, simply charge for 10 minutes and get up to 1 hour of playtime.
4 Microphones for Crystal-Clear Calls
Each earbud has two microphones with beamforming noise reduction and cVc 8.0 technology for superior vocal enhancement and background-noise suppression. This ensures your voice is heard clearly on the other end—without interference.
Incredible Sound
Life Note’s graphene drivers oscillate with extreme precision to give your music a wider soundstage with exceptional accuracy and clarity across the entire frequency range. Bass is further enhanced by up to 43% by our exclusive BassUp technology which analyzes low frequencies in real-time and instantly intensifies them. aptX audio allows you to stream music with CD-like audio quality thanks to lossless transmission between your device and the wireless earbuds.
Water-Resistant
Life Note wireless earbuds boast IPX5-rated protection against liquids. The water-resistant casing allows you to keep your conversation going and the music playing—even if you’re caught in heavy downpours.
One-Step Pairing
Our proprietary PUSH AND GO technology streamlines the setup process so when you remove the wireless earbuds from the charging case, they’ll automatically connect to the last paired device.
Product Description | Soundcore Life Note - true wireless earphones with mic | Product Type | True wireless earphones - Bluetooth | Recommended Use | Portable electronics | Colour | White | Headphones Form Factor | In-ear | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Stereo | Sound Effects | BassUp | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 92 dB | Diaphragm Type | Graphene | Microphone Operation Mode | Beamforming | Microphone Noise Cancelling | Yes | Microphones Included | 4 | Manufacturer Warranty | 18 months warranty |
General | |
Product Type | True wireless earphones - Bluetooth - wireless |
Colour | White |
Protection | IPX5, water-resistant |
Audio Output | |
Connectivity Technology | Wireless |
Bluetooth Audio Codec | aptX |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 92 dB |
Diaphragm | Graphene |
Microphone | |
Form Factor | Built-in |
Noise Cancelling Technology | cVc 8.0 (clear Voice capture) by Qualcomm |
Miscellaneous | |
Included Accessories | Charging case |
Cable Details | USB-C cable - detachable |
Compliant Standards | IPX5 |
Power | |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 5 hour(s) |
Run Time Details | Continuous playback: up to 5 hours , Continuous playback (with included charging case): up to 40 hours |
Manufacturer Warranty | |
Service & Support | Limited warranty - 18 months |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
