Experience deep contrast with the 22P1! Its Full HD panel offers wide viewing angles. Connect any source with VGA, DVI, HDMI, DisplayPort inputs.
Product Description | AOC 22P1 - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class E | Power Consumption (On mode) | 15.6 W | Panel Type | MVA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.24795 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 50000000:1 (dynamic) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, DisplayPort, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Matte | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 50.4 cm x 19.9 cm x 50.6 cm | Environmental Standards | TCO Certified Displays 8 | Compliant Standards | TUV GS, GOST, RoHS, REACH, DisplayPort 1.2, ISPO | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | MVA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Dimensions (WxDxH) | 50.4 cm x 19.9 cm x 50.6 cm - with stand |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , DVI , Headphones , 4 x USB 3.0 |
Mechanical | |
Tilt Angle | -3.5/+21.5 |
Swivel Angle | 175 |
Height Adjustment | 130 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x DVI cable |
MTBF | 50,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 15.6 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight (Shipping) | |
Shipping Width | 71.5 cm |
Shipping Depth | 15.9 cm |
Shipping Height | 38.7 cm |
Shipping Weight | 6.2 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
