We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This is the perfect companion for leisurely gamers with its 75 Hz refresh rate, 1 ms response time (MPRT) and FreeSync. Its IPS display ensures vivid and accurate colors.
Connectors
Product Description | AOC Gaming 24G2U5/BK - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Energy Consumption per Year | 32 kWh | Power Consumption (On mode) | 18 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 1 ms (MPRT) | Gaming | Yes | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 53.905 cm x 22.736 cm x 50.461 cm | Weight | 4.25 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | FCC, RoHS, Lead-Free, TUV Bauart, EAC, ISO 9241-307 Class 1, Mercury-free |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean |
Features | Flicker Free technology, USB 3.0 Fast Charge, Low Blue Light technology |
Colour | Black |
Dimensions (WxDxH) | 53.905 cm x 22.736 cm x 50.461 cm - with stand |
Weight | 4.25 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort 1.2 , VGA (HD-15) , Headphones (mini-jack) , Audio line-in , 4 x USB 3.0 |
Mechanical | |
Tilt Angle | 3.5/21.5 |
Swivel Angle | 60 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18 kWh/1000h |
Power Consumption (Typical) | 21 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 53.905 cm - depth: 4.72 cm - height: 32.21 cm - weight: 2.95 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 60.5 cm |
Shipping Depth | 18.4 cm |
Shipping Height | 49.2 cm |
Shipping Weight | 6.2 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
