Total comfort and connectivity in a 27" Full HD display with USB-C and KVM.
Product Description | AOC 27P2C - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class E | Power Consumption (On mode) | 20.5 W | Features | USB 3.2 Gen 1 hub, USB PD 65 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.3114 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Colour Gamut | 100% sRGB, 73% Adobe RGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare 3H hardness | Voltage | AC 100 - 240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - without stand | 61.36 cm x 5.11 cm x 36.95 cm | Environmental Standards | TCO Certified Displays 8 | Compliant Standards | DisplayPort 1.2 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class F |
Diagonal Size | 27" |
Built-in Devices | USB 3.2 Gen 1 hub |
USB Power Delivery | 65 Watt |
Panel Type | IPS |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Polish, Finnish, Russian, Spanish, Japanese |
Features | Flicker Free technology, borderless |
Colour | Black |
Dimensions (WxDxH) | 61.36 cm x 5.11 cm x 36.95 cm - without stand |
Audio | |
Type | Speakers |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | USB-C (power up to 65W) , HDMI , 4 x USB 3.2 Gen 1 , DisplayPort , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | HDMI cable - 1.8 m , DisplayPort cable - 1.8 m , Audio cable - 1.8 m |
Power | |
Input Voltage | AC 100 - 240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 20.5 kWh/1000h |
Power Consumption HDR (On mode) | 22.5 kWh/1000h |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
