34" curved gaming monitor with 144 Hz, 1ms response time and 21:9 wide screen resolution.
Product Description | AOC Gaming CU34G2X/BK - LED monitor - curved - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Power Consumption (On mode) | 42 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | VA | Aspect Ratio | 21:9 | Native Resolution | WQHD 3440 x 1440 at 144 Hz | Pixel Pitch | 0.2316 mm | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 / 80000000:1 (dynamic) | Response Time | 1 ms (MPRT) | Gaming | Yes | Colour Support | 16.7 million colours | Colour Gamut | 119% sRGB, 88% Adobe RGB | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, swivel, tilt | Screen Coating | 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Compliant Standards | DisplayPort 1.2 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 34" |
Built-in Devices | USB 3.0 hub |
Panel Type | VA |
Vertical Refresh Rate | 48 - 146 Hz |
Horizontal Refresh Rate | 30 - 160 kHz |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean |
Features | Flicker Free technology, frameless bezel design |
Colour | Black |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Headphones , 4 x USB 3.0 downstream , USB 3.0 upstream |
Mechanical | |
Tilt Angle | 3.5/21.5 |
Swivel Angle | 30 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 42 kWh/1000h |
Power Consumption HDR (On mode) | 65 kWh/1000h |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
