AOC AOC E2275PWJ 21.5 INCH LED 2MS VGA DVI HDMI SPEAKERS HA
£117.08
Delivery:
Product codes
This all around top performer is the ideal solution for a variety of business settings. The 21.5-inch E2275PWJ delivers rich, vivid imagery in Full HD (1920x1080) resolution, plus offers fast 2ms response time to handle your most demanding applications. Integrated VGA, DVI and HDMI connectors make it easy to hook up a computer, laptop and a range of other devices. The built-in speakers and headphone jack provide extra convenience for online calls and more. To ensure you work in comfort, the ergonomic stand easily adjusts to a variety of positions (including pivot mode) and Flicker Free technology helps reduce eye fatigue.
Product Description AOC Pro-line E2275PWJ - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Energy Class Class B
Energy Consumption per Year 32 kWh
Power Consumption (On mode) 22 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 200000000:1 (dynamic)
Response Time 2 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 50.4 cm x 21.29 cm x 46.88 cm
Weight 4.8 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, FCC, RoHS, TCO '06, TUV Bauart, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC AOC E2275PWJ 21.5...
£117.08
