AOC AOC Pro-line E2475SWJ - LCD monitor - 23.6" - 1920 x...
AOC AOC Pro-line E2475SWJ - LCD monitor - 23.6" - 1920 x 1080
£121.12
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • HDMI
  • VESA mount
  • Kensington Lock
  • Integrated speakers
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £124.61
Save £1.50
This all around top performer offers the ideal solution for a variety of business settings. With optimized brightness and high contrast ratios, the 23.6-inch E2475SWJ delivers sharp, vivid imagery in Full HD (1920 x 1080) resolution. Fast 2ms response time handles videos, animations and the most demanding software applications with ease. Integrated VGA, DVI and HDMI connectors make it easy to connect a computer, laptop and a range of other devices. The built-in speakers and headphone jack offer extra convenience for online calls and more. And to keep you working in comfort, Flicker Free technology helps reduce eye fatigue.
Product Description AOC Pro-line E2475SWJ - LCD monitor - Full HD (1080p) - 23.6"
Device Type LCD monitor - 23.6"
Energy Class Class A
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 23 W
Panel Type TN
Aspect Ratio Widescreen - 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2715 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 2 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) - with stand 55.88 cm x 19.85 cm x 42.46 cm
Weight 3.25 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, FCC, RoHS, TCO '06, TUV Bauart, EAC
Manufacturer Warranty 3 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC AOC Pro-line E2475...
£121.12
