AOC AOC Value M2470SWH - LED monitor - 23.6" (23.6"...
Key features
  • Plug and Play
  • 1 ms GTG response time
Product codes
With Full HD resolution and high contrast ratios, the 23.6-inch M2470SWH display offers brilliant picture quality and sharp, clear imagery - even on the darkest areas of the screen. Perfect for a range of home computing requirements, this monitor really excels at fast-paced entertainment like games and movies with ultra-fast 1 ms response time for lag-free action. Advanced MVA panel technology delivers ultra-wide viewing angles of 178 degrees to ensure you'll see every detail, no matter where you're sitting. Integrated VGA and HMDI ports make it easy to connect your computer, media center, game console and more, plus the built-in speakers and headphone jack are ideal for listening to music or catching up with friends.
Product Description AOC Value M2470SWH - LED monitor - Full HD (1080p) - 23.6"
Device Type LED-backlit LCD monitor - 23.6"
Energy Class Class A
Energy Consumption per Year 30 kWh
Power Consumption (On mode) 21 W
Panel Type MVA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2715 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Input Connectors 2xHDMI, VGA
Speakers Integrated
Colour Black
Dimensions (WxDxH) - with stand 55.14 cm x 22.1 cm x 40.04 cm
Weight 3.58 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, TCO Displays 6.0, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC AOC Value M2470SWH...
