This model targets business and home office users alike. Hidden behind its classically designed case is the LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
Product Description | AOC e2260Pda - LED monitor - 22" | Device Type | LED-backlit LCD monitor - 22" | Aspect Ratio | 16:10 | Native Resolution | 1680 x 1050 at 60 Hz | Pixel Pitch | 0.282 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Dimensions (WxDxH) | 50.78 cm x 52.13 cm x 24.46 cm | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | DDC-1, DDC-2B, DDC/CI | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 22" |
Vertical Refresh Rate | 75 Hz |
Horizontal Refresh Rate | 83 kHz |
Video Bandwidth | 146 MHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Features | HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+ |
Connectivity | |
Interfaces | DVI-D (HDCP) , VGA |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 178 |
Rotation Angle | 94 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable , 1 x DVI cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 15.5 Watt |
Power Consumption Stand by / Sleep | 0.4 Watt |
Power Consumption Stand by | 0.4 Watt |
Power Consumption Sleep | 0.34 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
