The e2260Pq is a true statement regarding both performance and design. Thanks to its LED backlights, this 55.9 cm (22") model is not only highly energy-efficient, but also has an elegant slim appearance. Coming in the practical 16:10 format with Wide XGA+ resolution, the e2260Pq offers extra desktop space in height compared to standard widescreen models - just perfect for lengthy tables, long documents and busy e-mail clients. With a pixel response time of 2 ms only, a high typical contrast of 1000:1 and a 250 cd/m2 luminance, the e2260Pq stands for super-smooth imaging. Users also benefit from integrated speakers and the ergonomic flexibility, allowing to tilt and swivel the monitor, adjust its height and even to use it in portrait mode (pivot). Next to a D-Sub input, the e2260Pq also provides digital DVI-D and DisplayPort connectors.
Product Description | AOC e2260Pq - LED monitor - 22" | Device Type | LED-backlit LCD monitor - 22" | Panel Type | TN | Aspect Ratio | 16:10 | Native Resolution | 1680 x 1050 at 60 Hz | Pixel Pitch | 0.282 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 2 ms (gray-to-gray) | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black | Dimensions (WxDxH) - with stand | 50.78 cm 24.46 cm | Weight | 5.65 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, RoHS, ISO 9241-307, EuP | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Panel Type | TN |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 146 MHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Features | HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+ |
Colour | Black |
Dimensions (WxDxH) | 50.78 cm 24.46 cm - with stand |
Weight | 5.65 kg |
Audio | |
Type | Speakers |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DVI-D , VGA , DisplayPort |
Mechanical | |
Tilt Angle | -5/+22 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable , 1 x DVI cable |
Power | |
Power Supply | Internal |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 19 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
