AOC E2260PQ/BK 22" 1680x1050 2ms DVI-D DP LED Monitor
£172.00
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 1680 x 1050 resolution
  • Height adjustment
  • DisplayPort input
  • Eco mode
  • Diagonal Size: 22in
  • Max Resolution: 1680 x 1050
  • Response Time: 2ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The e2260Pq is a true statement regarding both performance and design. Thanks to its LED backlights, this 55.9 cm (22") model is not only highly energy-efficient, but also has an elegant slim appearance. Coming in the practical 16:10 format with Wide XGA+ resolution, the e2260Pq offers extra desktop space in height compared to standard widescreen models - just perfect for lengthy tables, long documents and busy e-mail clients. With a pixel response time of 2 ms only, a high typical contrast of 1000:1 and a 250 cd/m2 luminance, the e2260Pq stands for super-smooth imaging. Users also benefit from integrated speakers and the ergonomic flexibility, allowing to tilt and swivel the monitor, adjust its height and even to use it in portrait mode (pivot). Next to a D-Sub input, the e2260Pq also provides digital DVI-D and DisplayPort connectors.
Product Description AOC e2260Pq - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Response Time 2 ms (gray-to-gray)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 50.78 cm 24.46 cm
Weight 5.65 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, RoHS, ISO 9241-307, EuP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC E2260PQ/BK 22" 168...
£172.00
