This LED-backlit monitor delivers a solid performance for standard office and home applications. Coming in a classy black texturised finish, the tiltable widescreen model is equipped with a fast-reacting TN panel, boasting a 5 ms pixel response time for crisp, blur-free images. Intelligent programs such as Screen+ and i-Menu enhance the user experience and help to save energy. The eco-friendly series 70 fulfils demanding sustainability certificates such as ENERGY STAR 6.0 and EPEAT Silver and is prepared for both VESA wall mount and Kensington security devices.
Product Description | AOC e2270Swdn - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 200 cd/m² | Contrast Ratio | 700:1 / 20000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Colour | Black | Dimensions (WxDxH) | 50.337 cm x 4.8 cm x 31.11 cm | Weight | 2.7 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | TN |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 90 |
Vertical Viewing Angle | 65 |
Backlight Technology | WLED |
Features | I-Menu, e-Saver technology, Screen+ |
Colour | Black |
Weight | 2.7 kg |
Connectivity | |
Interfaces | DVI-D , VGA |
Mechanical | |
Tilt Angle | -5/+15 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable - 1.2 m , 1 x DVI cable - 1.5 m |
Backlight Life | 50000 hours |
Power | |
Voltage Required | AC 100/240 V (50/60 Hz) |
Power Consumption Operational | 18.19 Watt |
Power Consumption Stand by | 0.2 Watt |
Power Consumption (Off Mode) | 0.2 Watt |
Dimensions & Weight (Shipping) | |
Shipping Width | 56 cm |
Shipping Depth | 11 cm |
Shipping Height | 39.5 cm |
Shipping Weight | 3.45 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
