The 24-inch AOC e2460Sh display was designed with speed in mind. The ultra-fast GTG response time makes it perfect for passionate gamers, as well as anyone who uses graphics, animation and film editing applications. Full HD resolution reveals the finest details while the impressive dynamic contrast delivers sharp imagery with deep, true blacks. The built-in speakers offer rich, clear sound for movies, music or video calls. The stand easily tilts the screen to a comfortable position, or use the VESA mount to hang it on the wall. VGA, DVI and HDMI connectors let you hook up multiple computers, devices and peripherals.
Product Description | AOC Value e2460Sh - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class A | Energy Consumption per Year | 32 kWh | Power Consumption (On mode) | 22 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.276 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Colour | Black | Dimensions (WxDxH) - with stand | 56.54 cm x 21.93 cm x 41.16 cm | Weight | 4.27 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, RoHS, ISO9241-307, Ukrain Safety | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 24" |
Panel Type | TN |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 165 MHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Features | HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+ |
Colour | Black |
Dimensions (WxDxH) | 56.54 cm x 21.93 cm x 41.16 cm - with stand |
Weight | 4.27 kg |
Audio | |
Type | Speakers - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , HDMI , DVI-D , Audio line-out |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable , 1 x HDMI cable |
Power | |
Power Supply | Internal |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 22 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.3 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
