AOC E2470SWHE 23.6" 1920x10805ms VGA DVI HDMI LED Monitor
£110.40
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Resolution 1920x1080@60 Hz
  • D-Sub, HDMI
  • Response time 5 ms
  • Plug and play
  • i-Menu
  • e-Saver
  • Screen+
  • Vesa Wallmount
  • Diagonal Size: 23.6in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: [N/A]
  • Interfaces: HDMI, VGA (HD-15)
Product codes
The E2470SWHE comes in a timelessly classic black design equipped with a high-quality 59.9 cm (23.6") Full HD panel. Delivering superb picture quality thanks to a high typical contrast of 1000:1 in combination with a 250 cd/m² luminosity and a pixel response time of 5 ms only, the E2470SWHE is perfectly equipped for both office and entertainment applications. Simply connect your AV sources via the model's D-Sub or two HDMI ports and enjoy flawless picture quality. Despite its large screen, this 23.6" monitor bargain consumes a mere 26 watts in standard mode. Furthermore, AOC fits out all of its monitors with clever software and presets to further save energy and enhance the overall user experience. Let the e2470Swhe stun you today.
Product Description AOC E2470SWHE - LED monitor - Full HD (1080p) - 23.6"
Device Type LED-backlit LCD monitor - 23.6"
Energy Class Class B
Energy Consumption per Year 37 kWh
Power Consumption (On mode) 25 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) 55.14 cm x 7.82 cm x 39.69 cm
Weight 3.58 kg
Environmental Standards ENERGY STAR Qualified EPEAT Silver
Compliant Standards EPA 6.0
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC E2470SWHE 23.6" 19...
£110.40
