AOC E719SDA 17" 1280x1024 5ms VGA DVI-D Black Monitor wi...
AOC E719SDA 17" 1280x1024 5ms VGA DVI-D Black Monitor with Speakers
£108.80
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 43.2 cm visible screen size
  • 250 cd/m2 brightness
  • 5 ms response time
  • HDCP compatible
  • D-sub analog input
  • DVI-D digital input
  • Diagonal Size: 17in
  • Max Resolution: 1280 x 1024
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
The e719Sda offers a 17" diagonal screen in picture format 5:4. The e719Sda delivers a high typical contrast of 1000:1 and a fast pixel response time of 5 ms, this monitor is great for standard office applications such as text editing, web browsing or e-mail correspondence. With 250 cd/m², the e719Sda delivers enough luminance to also be used in environments with bright ambient light. The integrated loudspeakers allow listening to play system sounds or other audio content. Via D-Sub or DVI-D, contents can be displayed in SuperXGA resolution. The energy-efficient LED-backlights allows the e719Sda to fulfil demanding sustainability certificates such as EPEAT Silver and Energy Star 6.0. AOC equips the monitor with intelligent software to further reduce power consumption.
Product Description AOC e719Sda - LED monitor - 17"
Device Type LED-backlit LCD monitor - 17"
Panel Type TN
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 75 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Input Connectors DVI-D, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black, silver
Dimensions (WxDxH) 37.16 cm x 5.89 cm x 32.67 cm
Weight 3.86 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TCO Displays 6.0, EPA 6.0
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC E719SDA 17" 1280x1...
£108.80
