AOC Featured U2879VF 28" LED Monitor
£259.99
Delivery:
Key features
  • Flicker Free
  • PiP
  • Fast response time
Product codes
The visually impressive U2879VF combines an expansive 28? screen size with 4K Ultra HD resolution for super-sharp, highly detailed images. The 10-bit Deep Color panel can display over a billion hues simultaneously, for superb realism and natural shading. A blisteringly fast screen response time shows fast-moving action without blurring, while AMD FreeSync technology matches the graphics signal to the screen timing to eliminate stuttering and tearing.
Ultra-high dynamic contrast intelligently adjusts brightness to reveal darker image details with greater depth and clarity. A full range of input connectors, including fast DisplayPort and dual-link DVI technologies, ensure compatibility with every device. The audio jack allows convenient attachment of headphones or desktop speakers.
Product Description AOC U2879VF - LED monitor - 28"
Device Type LED-backlit LCD monitor - 28"
Energy Class Class B
Energy Consumption per Year 64 kWh
Power Consumption (On mode) 44 W
Adaptive-Sync Technology AMD FreeSync
Panel Type TN
Aspect Ratio 16:9
Native Resolution 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz, DVI: 30 Hz)
Pixel Pitch 0.16 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 1.073 billion colours (8-bit)
Input Connectors HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments Tilt
Colour Black & silver
Dimensions (WxDxH) 65.93 cm x 4.87 cm x 37.94 cm
Weight 4 kg
Environmental Standards TCO Certified Displays 8
Compliant Standards Plug and Play, BSMI, DDC-2B, CCC, FCC, RoHS, WEEE, cTUVus, EPA, DDC-2B/CI, RCM, ISO9241-307
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC Featured U2879VF 2...
£259.99
