AOC I2490PXQU/BT 23.8" 1920x1080 4ms HDMI VGA DisplayPor...
AOC I2490PXQU/BT 23.8" 1920x1080 4ms HDMI VGA DisplayPort LED Monitor
£165.79
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Integrated speakers
  • Heigt adjustable stand
  • Full HD resolution
  • IPS panel
  • Diagonal Size: 23.8in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The AOC I2490PXQU has an appealing look with 3-sided frameless design and a flexible, sturdy stand with multiple ergonomic options. Its 23.8-inch IPS panel delivers sharp and vivid images covering 90% of the NTSC and 100% of the sRGB color gamut. The I2490PXQU excels at color uniformity and color accuracy. In addition to its wide viewing angles of up to 178°, its ergonomic base supports -5° /25° tilt, -165°/165° swivel, 130 mm height adjustment and pivot (90°) capability, which guarantees working comfort in every setting. Its HDMI, VGA and DisplayPort inputs offer a variety of connection options. Users spending long hours in front of a monitor will be relieved with the Flicker-Free technology reducing flicker by regulating backlight, and the low blue light mode reducing the harmful short wavelength blue light. The energy-efficient I2490PXQU is also certified with ecolabels such as Energy Star, EPEAT and TCO.
Product Description AOC I2490PXQU/BT - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Energy Class Class A+
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 4 ms
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, swivel, tilt
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC I2490PXQU/BT 23.8"...
£165.79
