AOC I960SRDA 19" 1280x1024 6ms DVI HDMI DP IPS Monitor
£119.08
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 19" diagonal size
  • Resolution: 1280x1024p
  • D-Sub, DVI
  • Fast response time of 14 ms
  • Plug and Play
  • VESA mountable
  • Diagonal Size: 19in
  • Max Resolution: 1280 x 1024
  • Response Time: 14ms
  • Speakers: Speaker(s)
  • Interfaces: DVI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £122.57
Save £1.50
This model targets business and home office users alike. Hidden behind its classically designed case is the advanced LED technology. It boasts a high typical contrast, ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel’s brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured finish.
Product Description AOC Pro-line I960SRDA - LED monitor - 19"
Device Type LED-backlit LCD monitor - 19"
Panel Type IPS
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 75 Hz
Pixel Pitch 0.294 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Input Connectors DVI, VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) - with stand 40.92 cm x 21 cm x 40.51 cm
Weight 2.85 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC I960SRDA 19" 1280x...
£119.08
